Ematic eGlide 4 Motherboard Replacement
    1. Ematic eGlide 4 Motherboard Replacement, Rear Panel: step 1, image 1 of 1
      • Remove the 4.6mm Phillips #00 screw at the base of the device.
      Ask FixBot
    2. Ematic eGlide 4 Motherboard Replacement: step 2, image 1 of 1
      • Slide the rear panel away from the base parallel to the screen.
      Ask FixBot
    3. Ematic eGlide 4 Motherboard Replacement: step 3, image 1 of 2 Ematic eGlide 4 Motherboard Replacement: step 3, image 2 of 2
      • Carefully remove the speakers from the rear panel.
      • Pull the speakers off of the rear panel.
      Ask FixBot
    1. Ematic eGlide 4 Motherboard Replacement, Speaker: step 4, image 1 of 1
      Ask FixBot
    1. Ematic eGlide 4 Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
      • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
      • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
      Ask FixBot
    2. Ematic eGlide 4 Motherboard Replacement: step 6, image 1 of 1
      • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
      • Remove the ribbon wire from the ribbon wire port on the screen board.
      Ask FixBot
    3. Ematic eGlide 4 Motherboard Replacement: step 7, image 1 of 1
      • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
      • Remove the ribbon wire from the ribbon wire port.
      • If you have already removed the side button array you do not need to do this step.
      Ask FixBot
    4. Ematic eGlide 4 Motherboard Replacement: step 8, image 1 of 1
      • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
      Ask FixBot
    5. Ematic eGlide 4 Motherboard Replacement: step 9, image 1 of 1
      • Desolder the Wi-Fi Adaptor
      • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
      • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
      Ask FixBot
    6. Ematic eGlide 4 Motherboard Replacement: step 10, image 1 of 1
      • Desolder the battery connections
      • If not replacing the motherboard or battery, omit this step
      Ask FixBot
    7. Ematic eGlide 4 Motherboard Replacement: step 11, image 1 of 2 Ematic eGlide 4 Motherboard Replacement: step 11, image 2 of 2
      • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
      • Lift the motherboard out of the device.
      Ask FixBot
Bailey Hughes
617 Reputation
6 Guides authored
Baylor, Team 5-8, Williams Spring 2015 Member of Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 89
All Time: 768
