Up to 20% off select tools
Ematic Model FTABMP2 Power Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
83
All Time:
703
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Ematic model #FTABMP2 won’t turn on or the power button is stuck or damaged, use this three-step guide to replace the power button.
The Ematic model #FTABMP2 is a small tablet device designed for children with its bulky plastic case. Turning it on is as simple as pressing the small plastic power button on its side. When the power button becomes stuck or damaged, the device cannot turn on.
This fix requires the iFixit Opening Tool for opening the plastic case and a replacement power button.
NOTE: Be careful when opening the device and exposing the motherboard. Consider purchasing iFixit's ESD safety gloves to decrease the risk of contamination to any sensitive parts in the motherboard.
    1. Ematic Model FTABMP2 Power Button Replacement, Power Button: step 1, image 1 of 2 Ematic Model FTABMP2 Power Button Replacement, Power Button: step 1, image 2 of 2
      • Use the opening tool to pry open the device case.
      Ask FixBot
    2. Ematic Model FTABMP2 Power Button Replacement: step 2, image 1 of 2 Ematic Model FTABMP2 Power Button Replacement: step 2, image 2 of 2
      • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp.
      • This will separate the device into two pieces.
      Ask FixBot
    3. Ematic Model FTABMP2 Power Button Replacement: step 3, image 1 of 1
      • The old power button will fall out by itself.
      • Replace it with the replacement button and secure it by clicking it into place.
      Ask FixBot
Author
with
Timothy
505 Reputation
5 Guides authored
USF Tampa, Team 9-2, Brown Winter 2015 Member of USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 83
All Time: 703
