Up to 20% off select tools
Ematic Model FTABMP2 Case Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
98
All Time:
666
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Ematic Model FTABMP2 Case Replacement, Case: step 1, image 1 of 2 Ematic Model FTABMP2 Case Replacement, Case: step 1, image 2 of 2
      • Use a spudger to open your device's case, revealing the inside.
      Ask FixBot
    2. Ematic Model FTABMP2 Case Replacement: step 2, image 1 of 2 Ematic Model FTABMP2 Case Replacement: step 2, image 2 of 2
      • Disconnect the LCD cable from the motherboard by pressing the two sides of the clamp together.
      Ask FixBot
    3. Ematic Model FTABMP2 Case Replacement: step 3, image 1 of 1
      • Use the spudger to pry the LCD from the clamps that hold it in the case.
      Ask FixBot
    4. Ematic Model FTABMP2 Case Replacement: step 4, image 1 of 2 Ematic Model FTABMP2 Case Replacement: step 4, image 2 of 2
      • If you need to remove the back part of the casing:
      • After disconnecting the LCD from the motherboard, remove the screws that hold down the motherboard.
      • Remove the plastic power and volume buttons.
      • Remove the two side grips of the device.
      Ask FixBot
    5. Ematic Model FTABMP2 Case Replacement: step 5, image 1 of 2 Ematic Model FTABMP2 Case Replacement: step 5, image 2 of 2
      • Remove the motherboard, the speaker, and the battery, leaving just the back casing of the device.
      Ask FixBot
Author
with
Timothy
505 Reputation
5 Guides authored
USF Tampa, Team 9-2, Brown Winter 2015 Member of USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 98
All Time: 666
