Up to 20% off select tools
Ematic Model FTABMP2 Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
85
All Time:
699
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in the Ematic Model FTABMP2, a tablet targeted towards children. The battery may need to be replaced if the device isn't turning on. To replace the battery, you will need a iFixIt opening tool as well as a Soldering Iron 60w Hakko 503F.
    1. Ematic Model FTABMP2 Battery Replacement, Battery: step 1, image 1 of 2 Ematic Model FTABMP2 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a spudger to pry open the case. Do this on the long side of the case. This will reveal the inside.
      Ask FixBot
    2. Ematic Model FTABMP2 Battery Replacement: step 2, image 1 of 2 Ematic Model FTABMP2 Battery Replacement: step 2, image 2 of 2
      • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
      Ask FixBot
    3. Ematic Model FTABMP2 Battery Replacement: step 3, image 1 of 2 Ematic Model FTABMP2 Battery Replacement: step 3, image 2 of 2
      • First, Remove the screws holding down the motherboard. Then remove the plastic power and volume buttons.
      • Next, remove the two side grips of the device. Now, you can remove the motherboard, speaker, and battery as one from the device.
      Ask FixBot
    4. Ematic Model FTABMP2 Battery Replacement: step 4, image 1 of 1
      • Unsolder the gray, black, and red wires from the motherboard to release the battery.
      Ask FixBot
Author
with
Timothy
505 Reputation
5 Guides authored
USF Tampa, Team 9-2, Brown Winter 2015 Member of USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 85
All Time: 699
