Up to 20% off select tools
Ematic Genesis 2 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
82
All Time:
941
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
    1. Ematic Genesis 2 Screen Replacement, Screen: step 1, image 1 of 2 Ematic Genesis 2 Screen Replacement, Screen: step 1, image 2 of 2
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      Ask FixBot
    2. Ematic Genesis 2 Screen Replacement: step 2, image 1 of 3 Ematic Genesis 2 Screen Replacement: step 2, image 2 of 3 Ematic Genesis 2 Screen Replacement: step 2, image 3 of 3
      • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
      • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
      Ask FixBot
    3. Ematic Genesis 2 Screen Replacement: step 3, image 1 of 2 Ematic Genesis 2 Screen Replacement: step 3, image 2 of 2
      • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
      • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
      Ask FixBot
    4. Ematic Genesis 2 Screen Replacement: step 4, image 1 of 1
      • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
      Ask FixBot
    5. Ematic Genesis 2 Screen Replacement: step 5, image 1 of 1
      • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
      • Install the new screen.
      Ask FixBot
Author
with
Brandon Key
246 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 82
All Time: 941
