Ematic Genesis 2 Charging Port Replacement
    1. Ematic Genesis 2 Charging Port Replacement, Charging Port: step 1, image 1 of 2 Ematic Genesis 2 Charging Port Replacement, Charging Port: step 1, image 2 of 2
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      Ask FixBot
    2. Ematic Genesis 2 Charging Port Replacement: step 2, image 1 of 3 Ematic Genesis 2 Charging Port Replacement: step 2, image 2 of 3 Ematic Genesis 2 Charging Port Replacement: step 2, image 3 of 3
      • Remove all four screws surrounding the battery with the Phillips head screwdriver.
      • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
      Ask FixBot
    3. Ematic Genesis 2 Charging Port Replacement: step 3, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 3, image 2 of 2
      • Remove both screws on either side of the audio jack using the Philips head screwdriver.
      • Detach audio jack from device.
      Ask FixBot
    4. Ematic Genesis 2 Charging Port Replacement: step 4, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 4, image 2 of 2
      • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
      • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
      Ask FixBot
    5. Ematic Genesis 2 Charging Port Replacement: step 5, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a soldering iron to heat the solder holding the charging port to the circuit board.
      • Remove the charging port from board using tweezers.
      Ask FixBot
    6. Ematic Genesis 2 Charging Port Replacement: step 6, image 1 of 1
      • Solder replacement port into place.
      • Make sure all connections match original.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 98
All Time: 891
