Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Parts
Tools
Introduction
Go to step 1 ↓This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Tool used on this step:Desoldering Pump$3.99
Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
Once all solder is gone, remove the wires from the device to free the battery.
2 other people completed this guide.
