Ematic Genesis 2 Audio Jack Repair
    1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: step 1, image 1 of 2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: step 1, image 2 of 2
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      Ask FixBot
    2. Ematic Genesis 2 Audio Jack Repair: step 2, image 1 of 3 Ematic Genesis 2 Audio Jack Repair: step 2, image 2 of 3 Ematic Genesis 2 Audio Jack Repair: step 2, image 3 of 3
      • Remove all four screws surrounding the battery with the screwdriver.
      • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
      Ask FixBot
    3. Ematic Genesis 2 Audio Jack Repair: step 3, image 1 of 1
      • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
      Ask FixBot
      • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 94
All Time: 445
