Ematic Funtab FTABXXX Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
102
All Time:
743
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Difficult
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Following our troubleshooting guide, you have diagnosed that you have a defective battery.
Tools
    1. Ematic Funtab FTABXXX Battery Replacement, Battery: step 1, image 1 of 2 Ematic Funtab FTABXXX Battery Replacement, Battery: step 1, image 2 of 2
      • First, be sure to power off the device.
      • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
      Ask FixBot
    2. Ematic Funtab FTABXXX Battery Replacement: step 2, image 1 of 1
      • Locate the battery. Generally located in the middle of the device.
      Ask FixBot
    3. Ematic Funtab FTABXXX Battery Replacement: step 3, image 1 of 2 Ematic Funtab FTABXXX Battery Replacement: step 3, image 2 of 2
      • Carefully pry off the battery from the display screen. This will be slight difficult since the battery is held onto the back of the display by adhesive.
      Ask FixBot
    4. Ematic Funtab FTABXXX Battery Replacement: step 4, image 1 of 1
      • Locate the red and black wire that runs from the battery and to the motherboard. Note the location of the wires, and carefully remove the soldered wires.
      Ask FixBot
    5. Ematic Funtab FTABXXX Battery Replacement: step 5, image 1 of 1
      • Attach the new battery to the same location as the old battery via adhesive.
      • Then, carefully solder the red wire to the '+' symbol on the motherboard and the black wire to the '-' symbol.
      Ask FixBot
    6. Ematic Funtab FTABXXX Battery Replacement: step 6, image 1 of 1
      • Once the solder has cooled, snap the front and back bezels together. Be sure to charge the new battery.
      Ask FixBot
Robert Zarobinski
269 Reputation
2 Guides authored
USF Tampa, Team 6-3, Brown Winter 2015 Member of USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 102
All Time: 743
