Up to 20% off select tools
Ematic FunTab 3 Touch Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
56
All Time:
1,442
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your device remains blank or seems to not power on when pressing the power button, a screen replacement may be necessary. If the device's display is damaged, this guide will show you the steps to replacing your defective screen. After following the necessary steps to remove the battery and motherboard, replacing the screen is very quick.
    1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: step 1, image 1 of 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: step 1, image 2 of 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: step 1, image 3 of 3
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Ask FixBot
    2. Ematic FunTab 3 Touch Screen Replacement: step 2, image 1 of 1
      • Pull the back panel away from the screen.
      Ask FixBot
    1. Ematic FunTab 3 Touch Screen Replacement, Motherboard: step 3, image 1 of 1
      • Remove the black tape to reveal the screen connector.
      Ask FixBot
    2. Ematic FunTab 3 Touch Screen Replacement: step 4, image 1 of 2 Ematic FunTab 3 Touch Screen Replacement: step 4, image 2 of 2
      • Flip up the retaining tab using the plastic opening tool.
      • Pull out the screen wire ribbon to disconnect the screen and motherboard.
      Ask FixBot
    3. Ematic FunTab 3 Touch Screen Replacement: step 5, image 1 of 2 Ematic FunTab 3 Touch Screen Replacement: step 5, image 2 of 2
      • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
      Ask FixBot
    4. Ematic FunTab 3 Touch Screen Replacement: step 6, image 1 of 1
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
      Ask FixBot
    1. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: step 7, image 1 of 2 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: step 7, image 2 of 2
      • Insert the hook side of the opening tool between the case and display.
      • Press down on the tool until the screen is clear of the white retaining tabs.
      • Use the plastic opening tool to gently pry up the screen.
      • This is best done on the corner closest to the wire ribbon.
      • Continue prying around the screen until the screen pops out.
      Ask FixBot
    2. Ematic FunTab 3 Touch Screen Replacement: step 8, image 1 of 1
      • After the screen has come lose, remove it from the device.
      • When reassembling, make sure the screen locks in place, this may require extra pressure
      Ask FixBot
Author
with
Amanda Davis
581 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Members
72 Guides authored
1 Guide Comment
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 56
All Time: 1,442
