Ematic FunTab 3 Speaker Replacement
    1. Ematic FunTab 3 Speaker Replacement, Back Panel: step 1, image 1 of 3 Ematic FunTab 3 Speaker Replacement, Back Panel: step 1, image 2 of 3 Ematic FunTab 3 Speaker Replacement, Back Panel: step 1, image 3 of 3
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Ask FixBot
    2. Ematic FunTab 3 Speaker Replacement: step 2, image 1 of 1
      • Pull the back panel away from the screen.
      Ask FixBot
    1. Ematic FunTab 3 Speaker Replacement, Speaker: step 3, image 1 of 2 Ematic FunTab 3 Speaker Replacement, Speaker: step 3, image 2 of 2
      Ask FixBot
    2. Ematic FunTab 3 Speaker Replacement: step 4, image 1 of 3 Ematic FunTab 3 Speaker Replacement: step 4, image 2 of 3 Ematic FunTab 3 Speaker Replacement: step 4, image 3 of 3
      • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
      • There is glue on the back of the speaker. Some more force may be required.
      Ask FixBot
Amanda Davis
581 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 73
All Time: 584
