Ematic FunTab 3 Motherboard Replacement
    1. Ematic FunTab 3 Motherboard Replacement, Back Panel: step 1, image 1 of 3 Ematic FunTab 3 Motherboard Replacement, Back Panel: step 1, image 2 of 3 Ematic FunTab 3 Motherboard Replacement, Back Panel: step 1, image 3 of 3
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Ask FixBot
    2. Ematic FunTab 3 Motherboard Replacement: step 2, image 1 of 1
      • Pull the back panel away from the screen.
      Ask FixBot
    1. Ematic FunTab 3 Motherboard Replacement, Battery: step 3, image 1 of 1
      • Remove the black tape to reveal the wire ribbon connector.
      Ask FixBot
    2. Ematic FunTab 3 Motherboard Replacement: step 4, image 1 of 3 Ematic FunTab 3 Motherboard Replacement: step 4, image 2 of 3 Ematic FunTab 3 Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Flip up the black retaining tab using the plastic opening tool.
      • Pull out the large wire ribbon that crosses over the battery.
      • You may need tweezers to pull out the wire ribbon.
      Ask FixBot
    3. Ematic FunTab 3 Motherboard Replacement: step 5, image 1 of 3 Ematic FunTab 3 Motherboard Replacement: step 5, image 2 of 3 Ematic FunTab 3 Motherboard Replacement: step 5, image 3 of 3
      • Insert the plastic opening tool under the battery.
      • Using the plastic opening tool, pry up the battery.
      • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
      Ask FixBot
    4. Ematic FunTab 3 Motherboard Replacement: step 6, image 1 of 2 Ematic FunTab 3 Motherboard Replacement: step 6, image 2 of 2
      • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
      • After the connections are desoldered, remove the battery.
      • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
      Ask FixBot
    1. Ematic FunTab 3 Motherboard Replacement, Speaker: step 7, image 1 of 2 Ematic FunTab 3 Motherboard Replacement, Speaker: step 7, image 2 of 2
      Ask FixBot
    2. Ematic FunTab 3 Motherboard Replacement: step 8, image 1 of 3 Ematic FunTab 3 Motherboard Replacement: step 8, image 2 of 3 Ematic FunTab 3 Motherboard Replacement: step 8, image 3 of 3
      • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
      • There is glue on the back of the speaker. Some more force may be required.
      Ask FixBot
    1. Ematic FunTab 3 Motherboard Replacement, Camera: step 9, image 1 of 2 Ematic FunTab 3 Motherboard Replacement, Camera: step 9, image 2 of 2
      Ask FixBot
    2. Ematic FunTab 3 Motherboard Replacement: step 10, image 1 of 1
      • Use the plastic opening tool to flip up the black retaining tab.
      Ask FixBot
    3. Ematic FunTab 3 Motherboard Replacement: step 11, image 1 of 2 Ematic FunTab 3 Motherboard Replacement: step 11, image 2 of 2
      • Pull out the wire ribbon connected to the camera.
      • The camera is held in place by glue, so extra force may be required.
      • Remove the camera from the device.
      Ask FixBot
    1. Ematic FunTab 3 Motherboard Replacement, Motherboard: step 12, image 1 of 1
      • Remove the black tape to reveal the screen connector.
      Ask FixBot
    2. Ematic FunTab 3 Motherboard Replacement: step 13, image 1 of 2 Ematic FunTab 3 Motherboard Replacement: step 13, image 2 of 2
      • Flip up the retaining tab using the plastic opening tool.
      • Pull out the screen wire ribbon to disconnect the screen and motherboard.
      Ask FixBot
    3. Ematic FunTab 3 Motherboard Replacement: step 14, image 1 of 2 Ematic FunTab 3 Motherboard Replacement: step 14, image 2 of 2
      • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
      Ask FixBot
    4. Ematic FunTab 3 Motherboard Replacement: step 15, image 1 of 1
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      Ask FixBot
Amanda Davis
581 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 56
All Time: 728
