Up to 20% off select tools
Ematic FunTab 3 Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
69
All Time:
1,215
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your device is not holding a charge, or only functions when plugged into the charger, then this guide will show how to fix this problem by replacing the battery. This process could take anywhere from 15-30 minutes, and requires you to detach and desolder all of the battery's connection to the device.
    1. Ematic FunTab 3 Battery Replacement, Back Panel: step 1, image 1 of 3 Ematic FunTab 3 Battery Replacement, Back Panel: step 1, image 2 of 3 Ematic FunTab 3 Battery Replacement, Back Panel: step 1, image 3 of 3
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Ask FixBot
    2. Ematic FunTab 3 Battery Replacement: step 2, image 1 of 1
      • Pull the back panel away from the screen.
      Ask FixBot
    1. Ematic FunTab 3 Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the black tape to reveal the wire ribbon connector.
      Ask FixBot
    2. Ematic FunTab 3 Battery Replacement: step 4, image 1 of 3 Ematic FunTab 3 Battery Replacement: step 4, image 2 of 3 Ematic FunTab 3 Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Flip up the black retaining tab using the plastic opening tool.
      • Pull out the large wire ribbon that crosses over the battery.
      • You may need tweezers to pull out the wire ribbon.
      Ask FixBot
    3. Ematic FunTab 3 Battery Replacement: step 5, image 1 of 3 Ematic FunTab 3 Battery Replacement: step 5, image 2 of 3 Ematic FunTab 3 Battery Replacement: step 5, image 3 of 3
      • Insert the plastic opening tool under the battery.
      • Using the plastic opening tool, pry up the battery.
      • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
      Ask FixBot
    4. Ematic FunTab 3 Battery Replacement: step 6, image 1 of 2 Ematic FunTab 3 Battery Replacement: step 6, image 2 of 2
      • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
      • After the connections are desoldered, remove the battery.
      • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
      Ask FixBot
Author
with
Amanda Davis
581 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 69
All Time: 1,215
