Up to 20% off select tools
Ematic FunTab 2 Motherboard Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
95
All Time:
1,761
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Tools
Introduction
Go to step 1 ↓
This replacement should take approximately an hour and a half (replacement time may vary). This guide details how to replace the tablet's motherboard by detaching and removing the motherboard after separating the motherboard from the other parts of the tablet.
    1. Ematic FunTab 2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
      Ask FixBot
    2. Ematic FunTab 2 Motherboard Replacement: step 2, image 1 of 3 Ematic FunTab 2 Motherboard Replacement: step 2, image 2 of 3 Ematic FunTab 2 Motherboard Replacement: step 2, image 3 of 3
      • Next, you need to remove all connections to the motherboard and the device.
      • Start by first removing the tape from all the connections.
      • Be careful not to remove the camera.
      Ask FixBot
    3. Ematic FunTab 2 Motherboard Replacement: step 3, image 1 of 3 Ematic FunTab 2 Motherboard Replacement: step 3, image 2 of 3 Ematic FunTab 2 Motherboard Replacement: step 3, image 3 of 3
      • Remove LCD connector from the LCD.
      • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
      Ask FixBot
    4. Ematic FunTab 2 Motherboard Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove camera connection from camera with tweezers.
      • Again, be sure to flip up the retaining tab before pulling the connector.
      Ask FixBot
    5. Ematic FunTab 2 Motherboard Replacement: step 5, image 1 of 1
      • Remove speaker connection from speaker with tweezers.
      • Before pulling the speaker connection make sure the retaining tab is flipped up.
      Ask FixBot
    6. Ematic FunTab 2 Motherboard Replacement: step 6, image 1 of 3 Ematic FunTab 2 Motherboard Replacement: step 6, image 2 of 3 Ematic FunTab 2 Motherboard Replacement: step 6, image 3 of 3
      • Remove wires:
      • Start by removing the black wire on each side.
      • Next, remove the WiFi antenna wire from the motherboard.
      • Finally, remove the yellow, red, and black wires.
      • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder How To Solder and Desolder Connections
      Ask FixBot
    7. Ematic FunTab 2 Motherboard Replacement: step 7, image 1 of 3 Ematic FunTab 2 Motherboard Replacement: step 7, image 2 of 3 Ematic FunTab 2 Motherboard Replacement: step 7, image 3 of 3
      • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
      • All of the screws are the same size, and should all fit in either corresponding screw location.
      Ask FixBot
    8. Ematic FunTab 2 Motherboard Replacement: step 8, image 1 of 2 Ematic FunTab 2 Motherboard Replacement: step 8, image 2 of 2
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      Ask FixBot
Author
with
Amanda Wolosz
287 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 95
All Time: 1,761
