Ematic Eglide 4 Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
91
All Time:
464
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace the internal speakers for your Ematic eGlide 4 and where to locate the speaker connection. The speakers are connected to the rear panel using a mild adhesive that does not need special care. The speakers are also connected to the motherboard via soldered wire connections, which must be desoldered in order to replace the speakers.
Parts
Tools
    1. Ematic Eglide 4 Speaker Replacement, Rear Panel: step 1, image 1 of 1
      • Remove the 4.6mm Phillips #00 screw at the base of the device.
      Ask FixBot
    2. Ematic Eglide 4 Speaker Replacement: step 2, image 1 of 1
      • Slide the rear panel away from the base parallel to the screen.
      Ask FixBot
    3. Ematic Eglide 4 Speaker Replacement: step 3, image 1 of 2 Ematic Eglide 4 Speaker Replacement: step 3, image 2 of 2
      • Carefully remove the speakers from the rear panel.
      • Pull the speakers off of the rear panel.
      Ask FixBot
    1. Ematic Eglide 4 Speaker Replacement, Speaker: step 4, image 1 of 1
      Ask FixBot
Bailey Hughes
617 Reputation
6 Guides authored
Baylor, Team 5-8, Williams Spring 2015 Member of Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 91
All Time: 464
