Up to 20% off select tools
Ematic EGQ307 LCD Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
87
All Time:
1,832
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Difficult
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If your LCD is no longer working or only half of the image is appearing you may need to replace it, in this guide you will learn exactly how to replace your tablets LCD.
    1. Ematic EGQ307 LCD Replacement, LCD: step 1, image 1 of 1
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      Ask FixBot
    2. Ematic EGQ307 LCD Replacement: step 2, image 1 of 2 Ematic EGQ307 LCD Replacement: step 2, image 2 of 2
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      Ask FixBot
    3. Ematic EGQ307 LCD Replacement: step 3, image 1 of 3 Ematic EGQ307 LCD Replacement: step 3, image 2 of 3 Ematic EGQ307 LCD Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
      Ask FixBot
    4. Ematic EGQ307 LCD Replacement: step 4, image 1 of 3 Ematic EGQ307 LCD Replacement: step 4, image 2 of 3 Ematic EGQ307 LCD Replacement: step 4, image 3 of 3
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with the spudger.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
      Ask FixBot
    5. Ematic EGQ307 LCD Replacement: step 5, image 1 of 3 Ematic EGQ307 LCD Replacement: step 5, image 2 of 3 Ematic EGQ307 LCD Replacement: step 5, image 3 of 3
      • Now LCD is removed and is ready to be replaced.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
Author
with
Jonathan Scinto
530 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 87
All Time: 1,832
