Up to 20% off select tools
Element GC-1020 Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
92
All Time:
853
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 seconds
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The battery in the GC-1020 device have two wires soldered (similar to being glued) to the logic board. It is fragile and needs to be handled with care.
    1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: step 1, image 1 of 1
      • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
      Ask FixBot
    2. Element GC-1020 Battery  Replacement: step 2, image 1 of 1
      • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
      • If you pull back too forcefully the power button would move out of place.
      Ask FixBot
    1. Element GC-1020 Battery  Replacement, Battery: step 3, image 1 of 2 Element GC-1020 Battery  Replacement, Battery: step 3, image 2 of 2
      • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
      • This replacement will require a soldering station.
      • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
      Ask FixBot
2 other people completed this guide.
Author
with
Lashaun Noel
591 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 92
All Time: 853
