Up to 20% off select tools
Electrolux LTE12 - Washing Machine Disassembly
Views: 10K
View statistics:
Past 24 Hours:
9
Past 7 Days:
46
Past 30 Days:
246
All Time:
10,473
Comments: 19
19 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Electrolux LTE12 - Washing Machine Disassembly, Electrolux LTE12 - Washing Machine Disassembly: step 1, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly, Electrolux LTE12 - Washing Machine Disassembly: step 1, image 2 of 2
      • Unplug the wall outlet.
      • Release the water hose.
      • Loosen the 4 Phillips screws at the top and 2 1/4 screws below.
      Ask FixBot
    2. Electrolux LTE12 - Washing Machine Disassembly: step 2, image 1 of 1
      • Fasten the lid of the washing machine with a large crepe tape. Do not open when removing the top of the machine.
      • There is no need to remove the glass cover to remove the top of the machine.
      Ask FixBot
    3. Electrolux LTE12 - Washing Machine Disassembly: step 3, image 1 of 1
      • Open the top of the washer. Lift the back first. And then the front.
      • Grip the top of the machine with care. Take care not to drop and break the cover glass.
      • Release the power cord and hose clips from the pressure switch.
      Ask FixBot
    4. Electrolux LTE12 - Washing Machine Disassembly: step 4, image 1 of 1
      • Remove the Phillips screw.
      • Remove the two plastic fasteners.
      • Remove the protective cap (semi-transparent) on the left side.
      Ask FixBot
    5. Electrolux LTE12 - Washing Machine Disassembly: step 5, image 1 of 1
      • Remove the two Phillips screws.
      • Remove the protective cap (semi-transparent) on the right side.
      Ask FixBot
    6. Electrolux LTE12 - Washing Machine Disassembly: step 6, image 1 of 1
      • To loosen the Control Panel cover, loosen the two Phillips screws. (Left side).
      Ask FixBot
    7. Electrolux LTE12 - Washing Machine Disassembly: step 7, image 1 of 1
      • To loosen the Control Panel cover, also loosen the two Phillips screws on the right side.
      Ask FixBot
    8. Electrolux LTE12 - Washing Machine Disassembly: step 8, image 1 of 1
      • Carefully lift the cover of the Control Panel. In this photo, the glass cover was removed to enlarge the image.
      Ask FixBot
    9. Electrolux LTE12 - Washing Machine Disassembly: step 9, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly: step 9, image 2 of 2
      • If there is a need to replace the Power Circuit Board, carefully pull out the program select button.
      • And then loosen the two Phillips screws.
      • Disconnect the cables carefully.
      Ask FixBot
    10. Electrolux LTE12 - Washing Machine Disassembly: step 10, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly: step 10, image 2 of 2
      • To remove the circuit board from the Panel buttons, remove the three Phillips screws. Disconnect the cable carefully.
      • When removing the circuit board from the buttons, be aware of the three button springs.
      Ask FixBot
    11. Electrolux LTE12 - Washing Machine Disassembly: step 11, image 1 of 3 Electrolux LTE12 - Washing Machine Disassembly: step 11, image 2 of 3 Electrolux LTE12 - Washing Machine Disassembly: step 11, image 3 of 3
      • If you need to replace any components on the button circuit board, loosen the three Phillips screws to remove the acrylic shield.
      • The problem with my machine was the power button. With a soldering iron and a sucker, I switched on the power switch.
      Ask FixBot
    12. Electrolux LTE12 - Washing Machine Disassembly: step 12, image 1 of 1
      • To change the pressure switch, cut the clamp and remove the
      • Disconnect wires.
      Ask FixBot
      • To assemble the Washing Machine, follow the same procedure, in the reverse order.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
7 other people completed this guide.
Special thanks to these translators:
pt en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Jose Gustavo Abreu Murta
5,212 Reputation
9 Guides authored
19 Guide Comments
muito boa a espricação
ramiro34676067 - Reply Share
Ola amigos boa noite. Estou como uma maquina de lavar eletrolux lt12f já troquei a placa de potencia e a de interface, agora ela fica com todos os leds ligados e o buzzer bipando sem parar.
Será que os amigos podem ame ajudar a identificar qual o problema?
Anael Dolesk - Reply Share
Anael, reveja todas as conexões e certifique-se que a placa principal é do modelo correto.
Sugiro desconectar os outros cabos e fazer um teste.
Jose Gustavo Abreu Murta - Reply Share
Minha máquina está girando de um lado só,ela não gira para os dois lados, só para o lado esquerdo,já olhei em baixo,tudo,fios as peças,oque pode ser?De resto tudo funciona,
Emanuela Peixoto Bortholo - Reply Share
Emanuela, a placa de circuito é que controla o motor. Portanto essa placa pode estar com defeito.
Past 24 Hours: 9
Past 7 Days: 46
Past 30 Days: 246
All Time: 10,473
