Electrohome EAAC475 Projector Lens Replacement
    1. Electrohome EAAC475 Projector Lens Replacement, Battery: step 1, image 1 of 2 Electrohome EAAC475 Projector Lens Replacement, Battery: step 1, image 2 of 2
      • Remove the 10 mm Phillips #1 screw from the battery cover.
      • Remove the battery cover.
      Ask FixBot
    2. Electrohome EAAC475 Projector Lens Replacement: step 2, image 1 of 1
      • Remove the flat lithium battery.
      Ask FixBot
    1. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: step 3, image 1 of 1
      • Slowly and carefully move one side away from another without detaching anything on the device.
      Ask FixBot
    2. Electrohome EAAC475 Projector Lens Replacement: step 4, image 1 of 1
      • Detach the projector.
      Ask FixBot
    3. Electrohome EAAC475 Projector Lens Replacement: step 5, image 1 of 2 Electrohome EAAC475 Projector Lens Replacement: step 5, image 2 of 2
      • Unplug the projector's connector from the circuit board.
      Ask FixBot
    4. Electrohome EAAC475 Projector Lens Replacement: step 6, image 1 of 1
      • Take off the rubber ring.
      Ask FixBot
    5. Electrohome EAAC475 Projector Lens Replacement: step 7, image 1 of 3 Electrohome EAAC475 Projector Lens Replacement: step 7, image 2 of 3 Electrohome EAAC475 Projector Lens Replacement: step 7, image 3 of 3
      • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
      • Slide the tool along the crease to separate.
      Ask FixBot
    6. Electrohome EAAC475 Projector Lens Replacement: step 8, image 1 of 1
      • Take the lens out of the projector.
      Ask FixBot
    7. Electrohome EAAC475 Projector Lens Replacement: step 9, image 1 of 1
      • Separate the lens and the gear by unscrewing the gear.
      Ask FixBot
Sterling Fulk
264 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Spring 2016 Member of IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 668
