Electrohome EAAC475 Display Replacement
    1. Electrohome EAAC475 Display Replacement, Battery: step 1, image 1 of 2 Electrohome EAAC475 Display Replacement, Battery: step 1, image 2 of 2
      • Remove the 10 mm Phillips #1 screw from the battery cover.
      • Remove the battery cover.
      Ask FixBot
    2. Electrohome EAAC475 Display Replacement: step 2, image 1 of 1
      • Remove the flat lithium battery.
      Ask FixBot
    1. Electrohome EAAC475 Display Replacement, Buttons: step 3, image 1 of 2 Electrohome EAAC475 Display Replacement, Buttons: step 3, image 2 of 2
      • Disconnect the radio from all power sources.
      • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
      • Remove two 10 mm Phillips #1 screws from the back side of the device.
      Ask FixBot
    2. Electrohome EAAC475 Display Replacement: step 4, image 1 of 3 Electrohome EAAC475 Display Replacement: step 4, image 2 of 3 Electrohome EAAC475 Display Replacement: step 4, image 3 of 3
      • Carefully and slowly pull the lower case away from the rest of the device.
      • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
      • Flip the device over to access the button assembly.
      • Slowly remove the button contact board from the assembly.
      Ask FixBot
    3. Electrohome EAAC475 Display Replacement: step 5, image 1 of 2 Electrohome EAAC475 Display Replacement: step 5, image 2 of 2
      • Remove the two 7 mm Phillips # 1 screws holding the buttons.
      • Remove the plastic buttons.
      Ask FixBot
    1. Electrohome EAAC475 Display Replacement, Display: step 6, image 1 of 2 Electrohome EAAC475 Display Replacement, Display: step 6, image 2 of 2
      • Remove the two 8 mm Phillips screws supporting the circuit board.
      • Pull off the circuit board to access the panels below.
      Ask FixBot
    2. Electrohome EAAC475 Display Replacement: step 7, image 1 of 2 Electrohome EAAC475 Display Replacement: step 7, image 2 of 2
      • Remove the two 6 mm Phillips screws supporting the mini circuit board for the frontal buttons.
      • Remove the mini circuit board.
      Ask FixBot
    3. Electrohome EAAC475 Display Replacement: step 8, image 1 of 2 Electrohome EAAC475 Display Replacement: step 8, image 2 of 2
      • Move the now free circuit boards away from the display.
      • Remove the final two 7 mm Phillips screws securing the display.
      • Pull the display screen away from the casing.
      Ask FixBot
    4. Electrohome EAAC475 Display Replacement: step 9, image 1 of 1
      • You have successfully accessed the display.
      • Replacing the display with a new one will be challenging as soldering and connecting micro wires are necessary.
      Ask FixBot
Sohail Khatri
201 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Spring 2016 Member of IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 29
All Time: 1,363
