Up to 20% off select tools
Electric Outlet Cover Replacement
Views: 11K
View statistics:
Past 24 Hours:
11
Past 7 Days:
54
Past 30 Days:
243
All Time:
10,636
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
In this guide I will be walking you through how to replace an electrical outlet cover. Keep in mind some outlets have different looks but here we will be replacing a standard outlet with two ports. Stay cautious when replacing an outlet cover because electric currents are still running through them and can potentially cause harm if not handled properly.
Before you begin this repair, we recommend you to turn off the electricity in your household to avoid electrocution.
    1. Electric Outlet Cover Replacement, Cover: step 1, image 1 of 1
      • Setup a workspace around the damaged/old electrical outlet cover you are replacing.
      Ask FixBot
    2. Electric Outlet Cover Replacement: step 2, image 1 of 2 Electric Outlet Cover Replacement: step 2, image 2 of 2
      • Use the flathead screwdriver to remove the screw from the outlet.
      • Lefty loose-y righty tight-y.
      Ask FixBot
    3. Electric Outlet Cover Replacement: step 3, image 1 of 3 Electric Outlet Cover Replacement: step 3, image 2 of 3 Electric Outlet Cover Replacement: step 3, image 3 of 3
      • Remove the faceplate off of the wall.
      Ask FixBot
    4. Electric Outlet Cover Replacement: step 4, image 1 of 1
      • Now that the faceplate is removed clean up the interior and surrounding area of the outlet.
      • Be cautious as you clean the exposed outlet due to the electric current still running through it.
      Ask FixBot
To make sure the outlet cover is properly installed, try to move the faceplate around and plug in your devices to ensure the outlet still works
3 other people completed this guide.
Author
with
Jason Villanueva
190 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 54
Past 30 Days: 243
All Time: 10,636
