Electric Lint Remover Blade Replacement
    1. Electric Lint Remover Blade Replacement, Blade: step 1, image 1 of 2 Electric Lint Remover Blade Replacement, Blade: step 1, image 2 of 2
      • Remove the lint container by sliding to the right until it clicks off.
      • Remove any lint from the lint container for a clean process.
      Ask FixBot
    2. Electric Lint Remover Blade Replacement: step 2, image 1 of 3 Electric Lint Remover Blade Replacement: step 2, image 2 of 3 Electric Lint Remover Blade Replacement: step 2, image 3 of 3
      • Rotate the perforated cap counterclockwise until it can be removed.
      Ask FixBot
    3. Electric Lint Remover Blade Replacement: step 3, image 1 of 2 Electric Lint Remover Blade Replacement: step 3, image 2 of 2
      • Use your flathead screwdriver to get in between the device and the blades.
      • Push the plastic blade holder outward from the device until it pops off.
      Ask FixBot
    4. Electric Lint Remover Blade Replacement: step 4, image 1 of 2 Electric Lint Remover Blade Replacement: step 4, image 2 of 2
      • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
      Ask FixBot
    5. Electric Lint Remover Blade Replacement: step 5, image 1 of 3 Electric Lint Remover Blade Replacement: step 5, image 2 of 3 Electric Lint Remover Blade Replacement: step 5, image 3 of 3
      • Insert the replacement blade into the empty slot.
      • Caution: pinching the replacement blade from surface may result in injury.
      Ask FixBot
    6. Electric Lint Remover Blade Replacement: step 6, image 1 of 2 Electric Lint Remover Blade Replacement: step 6, image 2 of 2
      • Flip the cap onto its backside and firmly hold down the side with the loose blade.
      • Pull back the wire using your fingers, and insert wire back into the blade hole.
      Ask FixBot
    7. Electric Lint Remover Blade Replacement: step 7, image 1 of 3 Electric Lint Remover Blade Replacement: step 7, image 2 of 3 Electric Lint Remover Blade Replacement: step 7, image 3 of 3
      • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
      • Press down gently on the plastic blade cap.
      • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
      Ask FixBot
    8. Electric Lint Remover Blade Replacement: step 8, image 1 of 2 Electric Lint Remover Blade Replacement: step 8, image 2 of 2
      • Place perforated cap on top of the blade cap and turn clockwise until tight.
      Ask FixBot
    9. Electric Lint Remover Blade Replacement: step 9, image 1 of 2 Electric Lint Remover Blade Replacement: step 9, image 2 of 2
      • Slide the lint container to the left and press until it clicks into place.
      Ask FixBot
We hope this guide helped you. Happy Fixing!
Chris Koenig
184 Reputation
1 Guide authored
CSU Los Angeles, Team 9-4, Ribeiro Fall 2023 Member of CSU Los Angeles, Team 9-4, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S9G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 61
All Time: 1,380
