Electric Eel Lower Feeder Assembly Replacement
  1. Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: step 1, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: step 1, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: step 1, image 3 of 3
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
    Ask FixBot
  2. Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: step 2, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: step 2, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: step 2, image 3 of 3
    • Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
    Ask FixBot
  3. Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: step 3, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: step 3, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: step 3, image 3 of 3
    • Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
    Ask FixBot
  4. Electric Eel Lower Feeder Assembly Replacement, Disengage the Top Bearing: step 4, image 1 of 2 Electric Eel Lower Feeder Assembly Replacement, Disengage the Top Bearing: step 4, image 2 of 2
    • Push the top control finger up as far as possible.
    • This disengages the top feeder assembly and allows the cable to freely move through the feeder. The finger may fall back down on its own and restrict cable movement. If this occurs, simply push the finger back up.
    Ask FixBot
  5. Electric Eel Lower Feeder Assembly Replacement, Remove the Auto-Feeder: step 5, image 1 of 1
    • Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
    Ask FixBot
  6. Electric Eel Lower Feeder Assembly Replacement: step 6, image 1 of 2 Electric Eel Lower Feeder Assembly Replacement: step 6, image 2 of 2
    • Remove the auto-feeder from the cable.
    • If the end of the cable won't pass through the feeder, ensure that the top bearing is completely disengaged as described in step 4 of this guide.
    Ask FixBot
  7. Electric Eel Lower Feeder Assembly Replacement, Install the Roll Pin: step 7, image 1 of 1
    • Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
    Ask FixBot
  8. Electric Eel Lower Feeder Assembly Replacement: step 8, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement: step 8, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement: step 8, image 3 of 3
    • Use a dead blow hammer or mallet to tap down the bearing carrier onto the roll pin until the pin just begins to peek into the bearing channel.
    • Ensure you are using the correct bearing carrier for this step. The top bearing assembly uses the shorter carrier, while the two lower bearing assemblies use the longer carrier.
    Ask FixBot
  9. Electric Eel Lower Feeder Assembly Replacement: step 9, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement: step 9, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement: step 9, image 3 of 3
    • Insert a bearing and the bearing spacer into the bearing channel.
    • Ensure that the bearing and spacer are aligned with the roll pin and hole in the bearing carrier.
    Ask FixBot
  10. Electric Eel Lower Feeder Assembly Replacement: step 10, image 1 of 1
    • Continue to tap down the bearing carrier until the bearing and spacer are fully secured around the roll pin.
    • You will need to unclamp and reposition the roll pin upwards to continue tapping it into the bearing carrier. Do this as many times as is necessary to sufficiently support the roll pin.
    Ask FixBot
  11. Electric Eel Lower Feeder Assembly Replacement: step 11, image 1 of 1
    • Use a roll pin punch to finish seating the roll pin into place.
    • Place a piece of cloth or mat on top of the vise below the bearing carrier to prevent marring the outer surface of the bearing carrier.
    • Before moving to the next step, ensure the roll pin is fully seated and completely within the bearing carrier. A slightly exposed roll pin may damage the inside of your feeder body when the bearing carrier assembly is being installed.
    Ask FixBot
  12. Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: step 12, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: step 12, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: step 12, image 3 of 3
    • Use a pair of snap ring pliers to remove the retaining ring at the bottom of the lower feeder assembly.
    Ask FixBot
  13. Electric Eel Lower Feeder Assembly Replacement, Remove the Thrust Bearings: step 13, image 1 of 2 Electric Eel Lower Feeder Assembly Replacement, Remove the Thrust Bearings: step 13, image 2 of 2
    • Use a pair of needle-nose pliers to remove the first thrust washer from the assembly.
    Ask FixBot
  14. Electric Eel Lower Feeder Assembly Replacement: step 14, image 1 of 2 Electric Eel Lower Feeder Assembly Replacement: step 14, image 2 of 2
    • Remove the thrust bearing from the assembly.
    Ask FixBot
  15. Electric Eel Lower Feeder Assembly Replacement: step 15, image 1 of 2 Electric Eel Lower Feeder Assembly Replacement: step 15, image 2 of 2
    • Remove the second thrust washer from the assembly.
    Ask FixBot
  16. Electric Eel Lower Feeder Assembly Replacement, Remove the Control Finger: step 16, image 1 of 1
    • Use a flathead screwdriver to remove the lower control finger from the assembly.
    Ask FixBot
  17. Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: step 17, image 1 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: step 17, image 2 of 3 Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: step 17, image 3 of 3
    • Use a flathead screwdriver or other long tool as leverage to remove the lower bearing carrier from the assembly.
    Ask FixBot
After reassembly: Ensure the assembly you just installed is sufficiently lubricated using the Zerk fitting on the feeder body.
Tarun Thiruma
40,423 Reputation
134 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 51
All Time: 2,106
