Electric Eel Drain Cleaner Guide Spring Replacement
  1. Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: step 1, image 1 of 3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: step 1, image 2 of 3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: step 1, image 3 of 3
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
    Ask FixBot
Tarun Thiruma
40,420 Reputation
134 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 814
