Up to 20% off select tools
Electric Bike Throttle Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
10
Past 7 Days:
69
Past 30 Days:
351
All Time:
3,594
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace your Electric Bike Throttle.
    1. Electric Bike Throttle Replacement, Brake: step 1, image 1 of 1
      • Before starting to disassemble your electric bike, turn the power off.
      • Remove the 3/32 inch Allen screw.
      • When removing Allen screw, make sure the driver is well seated because they are simple to strip.
      Ask FixBot
    2. Electric Bike Throttle Replacement, Throttle: step 2, image 1 of 1
      • Locate the throttle Allen screw.
      • Remove the 5/64 inch Allen screw.
      Ask FixBot
    3. Electric Bike Throttle Replacement, Throttle: step 3, image 1 of 1
      • Slide the Throttle off.
      • When removing the throttle, be careful. Remove it slowly to avoid damaging the wire.
      Ask FixBot
    4. Electric Bike Throttle Replacement, Control Box: step 4, image 1 of 1
      • Remove the following screws.
      • 2 mm Philips screws.
      Ask FixBot
    5. Electric Bike Throttle Replacement: step 5, image 1 of 1
      • Open up the control box.
      Ask FixBot
    6. Electric Bike Throttle Replacement: step 6, image 1 of 1
      • Track the throttle wire.
      • To ensure you don't lose it, you should mark it.
      Ask FixBot
    7. Electric Bike Throttle Replacement: step 7, image 1 of 1
      • Locate the throttle wire.
      • Disconnect the throttle wire plug from the controller wire plug.
      • Take caution while handling these wires. You can easily damage them.
      Ask FixBot
Author
with
Ali Al-hamadani
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 351
All Time: 3,594
