Electra Domed Ringer Bike Bell Rust Removal
  1. Electra Domed Ringer Bike Bell Rust Removal, Electra Domed Ringer Bike Bell Rust Removal: step 1, image 1 of 2 Electra Domed Ringer Bike Bell Rust Removal, Electra Domed Ringer Bike Bell Rust Removal: step 1, image 2 of 2
    • Twist the top cover to remove it from the bell.
    • If twisting does not work, pry around the edges of the top cover using a metal spudger to remove it.
    • If you need to pry off the top, you will need to glue or solder the top back on at the end.
  2. Electra Domed Ringer Bike Bell Rust Removal: step 2, image 1 of 2 Electra Domed Ringer Bike Bell Rust Removal: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to gently bend up the prongs on the metal four-pronged rings.
    • Use caution to not break the prongs off the rings.
  3. Electra Domed Ringer Bike Bell Rust Removal: step 3, image 1 of 2 Electra Domed Ringer Bike Bell Rust Removal: step 3, image 2 of 2
    • Remove the hammer by gently lifting it off of the spring.
    • Set the hammer aside with the other pieces.
  4. Electra Domed Ringer Bike Bell Rust Removal: step 4, image 1 of 3 Electra Domed Ringer Bike Bell Rust Removal: step 4, image 2 of 3 Electra Domed Ringer Bike Bell Rust Removal: step 4, image 3 of 3
    • Move the spring until it is off the spoke, then remove the spring from the metal band.
    • The spring most likely has rust, so be careful with removal.
    • Set the spring aside with the other parts.
  5. Electra Domed Ringer Bike Bell Rust Removal: step 5, image 1 of 3 Electra Domed Ringer Bike Bell Rust Removal: step 5, image 2 of 3 Electra Domed Ringer Bike Bell Rust Removal: step 5, image 3 of 3
    • Remove the lever by lifting it off the metal spoke.
    • Set the lever aside with the other parts.
    • Be careful with the metal band attached to the lever as it could bend out of its intended shape.
    • The metal band attached to the lever will be coated in rust, so be careful with removal.
  6. Electra Domed Ringer Bike Bell Rust Removal: step 6, image 1 of 2 Electra Domed Ringer Bike Bell Rust Removal: step 6, image 2 of 2
    • Place the rusty pieces into a bowl and pour white vinegar over them. Wait two hours.
    • Pull the pieces out carefully and clean the rust off of them. Let the pieces dry.
    • Dispose of the rust and the vinegar carefully. Do not consume the vinegar.
  7. Electra Domed Ringer Bike Bell Rust Removal: step 7, image 1 of 2 Electra Domed Ringer Bike Bell Rust Removal: step 7, image 2 of 2
    • If you had to pry the top off of your bell, you will have to glue or solder it back on.
    • Reassemble the bell, then either solder or glue the top back on.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 61
All Time: 1,339
