Up to 20% off select tools
Elastic Drawcord Replacement
Views: 12K
View statistics:
Past 24 Hours:
48
Past 7 Days:
341
Past 30 Days:
1,415
All Time:
12,397
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Parts
Tools
Introduction
Go to step 1 ↓
A drawcord is a length of cording, often elastic, that runs through hems, waistbands, hoods, and other areas where adjustable tightness is beneficial. Over time, a drawcord can stretch out and lose its elasticity, or it may break or snap during use. In these situations, replacing the entire drawcord is necessary.
This guide will demonstrate how to replace a drawcord without the need for sewing. To ensure this solution is applicable, confirm that the drawcord is not sewn into the item on either end.
While this tutorial focuses on a jacket hem, the same techniques can be applied to other non-sewn drawcords, such as those found in waistbands and hoods.
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
Related tutorial: Cord Lock Replacement
Return to the Patagonia Care & Repair homepage.
    1. Elastic Drawcord Replacement, Assess the damage: step 1, image 1 of 3 Elastic Drawcord Replacement, Assess the damage: step 1, image 2 of 3 Elastic Drawcord Replacement, Assess the damage: step 1, image 3 of 3
      • Assess the state of the drawcord - if it's damaged, stretched out, or missing entirely.
      • If original drawcord is present, take note of:
      • Design - How the drawcord is threaded into the garment (e.g. through hand pockets or a grosgrain loop)
      • Cord Lock - How the drawcord threads through the cord lock(s)
      • Other Pieces - If the drawcord is used with any additional hard trims like end caps or clear plastic discs
      • If the drawcord is missing entirely, please see Step 3.
      Ask FixBot
    2. Elastic Drawcord Replacement, Remove the damaged drawcord: step 2, image 1 of 3 Elastic Drawcord Replacement, Remove the damaged drawcord: step 2, image 2 of 3 Elastic Drawcord Replacement, Remove the damaged drawcord: step 2, image 3 of 3
      • On both ends of the drawcord:
      • Use flush cutters to pry off the tip of the end cap.
      • Pull the drawcord end out of the end cap and untie the knot.
      • Remove the base of the end cap and any plastic discs (if present).
      • Wear safety glasses.
      • Save all these pieces.
      • Unthread the drawcord by releasing the tension from the cord locks and pulling it out of the garment completely.
      • The drawcord end knots can also be cut for faster removal (reference image #2). If doing so, add 1 inch (~25 mm) to the measurement in Step 3.
      Ask FixBot
    3. Elastic Drawcord Replacement, Measure and cut the new drawcord: step 3, image 1 of 3 Elastic Drawcord Replacement, Measure and cut the new drawcord: step 3, image 2 of 3 Elastic Drawcord Replacement, Measure and cut the new drawcord: step 3, image 3 of 3
      • If the drawcord isn't stretched out or missing any part, use the old drawcord as a reference to measure and cut the appropriate length for a new one.
      • Alternatively, to measure and cut a new drawcord without the old one:
      • Measure the length of the hem.
      • Add the distance the cord travels to and from any cord locks.
      • Add 2 inches (~51 mm) to account for a 1 inch (~25 mm) seam allowance on each end.
      • Add an additional 1 inch (~25 mm) if the drawcord end knots were cut in Step 2.
      • Use a lighter to singe the cut ends of the drawcord.
      • Discard broken pieces responsibly.
      Ask FixBot
    4. Elastic Drawcord Replacement, Thread the drawcord into the hem: step 4, image 1 of 3 Elastic Drawcord Replacement, Thread the drawcord into the hem: step 4, image 2 of 3 Elastic Drawcord Replacement, Thread the drawcord into the hem: step 4, image 3 of 3
      • Use your fingers or a plastic drawstring threader to thread the new drawcord through the hem.
      • Once through the hem, double check that the drawcord length is correct.
      • Thread the drawcord through any cord locks and associated grosgrain tabs.
      Ask FixBot
    5. Elastic Drawcord Replacement, Thread the drawcord into pockets: step 5, image 1 of 3 Elastic Drawcord Replacement, Thread the drawcord into pockets: step 5, image 2 of 3 Elastic Drawcord Replacement, Thread the drawcord into pockets: step 5, image 3 of 3
      • Use a plastic drawstring threader, latch hook, bodkin, or safety pin to thread the drawcord ends into pockets.
      Ask FixBot
    6. Elastic Drawcord Replacement, Secure the new drawcord: step 6, image 1 of 3 Elastic Drawcord Replacement, Secure the new drawcord: step 6, image 2 of 3 Elastic Drawcord Replacement, Secure the new drawcord: step 6, image 3 of 3
      • Thread the plastic disc and the end cap base onto the drawcord end.
      • Tie a knot at the end of the drawcord. Pull it tight and snip or singe away any excess.
      • Pull the drawcord so the knot rests inside the end cap base.
      • Check that the knot doesn't pull through the end cap.
      • Replace end cap tip by snapping it into place.
      Ask FixBot
    7. Elastic Drawcord Replacement, Functionality test and quality control: step 7, image 1 of 3 Elastic Drawcord Replacement, Functionality test and quality control: step 7, image 2 of 3 Elastic Drawcord Replacement, Functionality test and quality control: step 7, image 3 of 3
      • Pull on the ends of the drawcord to make sure they're secured and that the drawcord is functioning properly.
      • Test the drawcord's function at each cord lock.
      • Make a final check on the drawcord length when the cord locks are loosened and the drawcord is laying naturally:
      • Too Tight - Not enough cord. The hemline will bunch.
      • Too Loose - Too much cord. Excess drawcord will either undulate inside the hemline or hang loosely from the cord locks.
      Ask FixBot
    8. Elastic Drawcord Replacement, Troubleshooting: step 8, image 1 of 3 Elastic Drawcord Replacement, Troubleshooting: step 8, image 2 of 3 Elastic Drawcord Replacement, Troubleshooting: step 8, image 3 of 3
      • VARIATIONS: There are many varieties of drawcords on the vast array of Patagonia items. The techniques and steps outlined in this tutorial can be rearranged or modified to fit the circumstances.
      • MISSING CORD: If the drawcord is missing entirely, use grosgrain loops, eyelets and rivets as context clues. Alternatively, try to find photos of the item on Patagonia.com, WornWear.com, and Google image search.
      • HOOD: Hood drawcords can be more complex with multiple lengths of elastic that can loop around one another. Be careful to examine the placement of drawcords in a hood before removing them.
      Ask FixBot
Finish Line
Author
with
Katherine Anick-Jenkins
157 Reputation
1 Guide authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
0 Guide Comments
Past 24 Hours: 48
Past 7 Days: 341
Past 30 Days: 1,415
All Time: 12,397
