Eibos Easdry heating system replacement
  1. Eibos Easdry heating system replacement, Prepare the Easdry: step 1, image 1 of 1
    • Put the Easdry flat on a table with its removable faceplate facing downwards, so that the fan intake is facing upwards.
    Ask FixBot
  2. Eibos Easdry heating system replacement, Open the backplate: step 2, image 1 of 3 Eibos Easdry heating system replacement, Open the backplate: step 2, image 2 of 3 Eibos Easdry heating system replacement, Open the backplate: step 2, image 3 of 3
    • The backplate of the Easdry is not held in place with any screws, so removing it is easy.
    • Put a metal spudger between the backplate and the casing, next to one of the plastic protrusions keeping the lid in place.
    • There are in total eight positions where the backplate is held in place.
    • Tilt the spudger away from the backplate, slowly lifting it up. Repeat this multiple times for each side until the backplate is more or less on top of the casing.
    Ask FixBot
  3. Eibos Easdry heating system replacement, Lift the backplate: step 3, image 1 of 1
    • Grab the backplate and gently pull it loose from the casing. It may need a bit of force, as there are also a few clips in the center of the backplate that keep it in place.
    • Do not apply too much force, as this could break the clips in the center, making it difficult to reassemble the backplate.
    Ask FixBot
  4. Eibos Easdry heating system replacement, Disconnect the motherboard: step 4, image 1 of 2 Eibos Easdry heating system replacement, Disconnect the motherboard: step 4, image 2 of 2
    • Pull the motherboard out of the bottom left corner of the casing. It is not kept in place by anything.
    • Disconnect all connectors on the motherboard. In total, there are four connectors.
    • Put the old motherboard away.
    Ask FixBot
  5. Eibos Easdry heating system replacement, Remove the fan: step 5, image 1 of 1
    • Put a metal spudger between the fan and the casing, and slowly wedge the fan upwards.
    • Do this for all four sides of the fan.
    • Once the fan is lifted sufficiently, grab it with your fingers and pull it out.
    • Put the old fan away.
    Ask FixBot
  6. Eibos Easdry heating system replacement, Remove the potentiometer: step 6, image 1 of 3 Eibos Easdry heating system replacement, Remove the potentiometer: step 6, image 2 of 3 Eibos Easdry heating system replacement, Remove the potentiometer: step 6, image 3 of 3
    • Pull off the black cap that's on top of the potentiometer. It has quite a snug fit, so some force is needed to pull it off.
    • No tools should be necessary here. Only your fingers should be sufficient to pull the cap off.
    • The potentiometer is kept in place by a screw nut. Remove this nut with a 10mm wrench.
    • Once the nut is off, pull the potentiometer out of the case.
    • Put the old potentiometer away, but keep the black cap.
    Ask FixBot
  7. Eibos Easdry heating system replacement, Remove the heating element: step 7, image 1 of 2 Eibos Easdry heating system replacement, Remove the heating element: step 7, image 2 of 2
    • The heating element is kept in place by two black clips on each side of the element.
    • Put two metal spudgers on each side of the heating element, between the element and the casing, next to the black clips.
    • Apply a bit of outward force to free up space for the heating element to slide out.
    • Gently pull on the two wires coming out of the heating element to pull it out of its casing.
    • Put the old heating element away.
    Ask FixBot
  8. Eibos Easdry heating system replacement, Insert the new heating element: step 8, image 1 of 1
    • Insert the new heating element in the now empty slot.
    • Take note of the orientation of the heating element.
    Ask FixBot
  9. Eibos Easdry heating system replacement, Insert the new potentiometer: step 9, image 1 of 3 Eibos Easdry heating system replacement, Insert the new potentiometer: step 9, image 2 of 3 Eibos Easdry heating system replacement, Insert the new potentiometer: step 9, image 3 of 3
    • Insert the new potentiometer in the same slot as the old one came out of.
    • Note that the potentiometer has a small clip that neatly falls inside the upper part of the slot. Make sure the potentiometer is oriented so that its clip falls into this slot as well.
    • Put both the washer and the nut screw back over the potentiometer, and tighten them with the wrench.
    • Grab the knob of the potentiometer with two fingers, and turn it counterclockwise until it stops.
    • Place the black cap back on top of the potentiometer, with the white indicator at the start of the green PLA section.
    • Once mounted, turn the black knob clockwise all the way, and verify that it is at the end of the dark-red PA section.
    Ask FixBot
  10. Eibos Easdry heating system replacement, Insert the new motherboard: step 10, image 1 of 1
    • Put the new motherboard back in its housing at the bottom left of the casing.
    • Pay attention to the direction the motherboard goes into its housing.
    Ask FixBot
  11. Eibos Easdry heating system replacement, Insert the new fan: step 11, image 1 of 2 Eibos Easdry heating system replacement, Insert the new fan: step 11, image 2 of 2
    • Guide all wires along their respective little trenches, to ensure no wires get pinched when the backplate is reassembled.
    • Insert the fan in its slot, while keeping the wires that go behind the fan down.
    • Pay attention to the direction of the fan. If mounted incorrectly, the fan will be blowing air out of the box instead of into the box. The blades of the fan should be curved upwards from the center outward.
    • Guide the remaining wire of the fan along its little trench, with the rest of the wires.
    Ask FixBot
  12. Eibos Easdry heating system replacement, Place the backplate back: step 12, image 1 of 1
    • Place the backplate back on top, with the warning text upright.
    • Push on all sides of the plate until it clicks into place.
    Ask FixBot
Congratulations on replacing the heating system! Turn the temperature knob to its highest setting, turn the dryer on, and check after 10 minutes if the inside of the dryer box is indeed hot. You can also check this by using a multimeter with temperature setting, if you have one.
UnrealKazu
250 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 48
All Time: 1,045
