Introduction
Go to step 1 ↓The following guide will help you replace any flimsy or loose wires on your kitchen egg slicer.
For an egg slicer to work properly, it depends on the tension of the wires, as it is what cuts the egg. A flimsy or loose wire cannot cut your egg properly and will not serve its purpose. Fixing the wire is a relatively simple fix that brings many benefits, such as extending the life of your egg slicer and reducing plastic waste.
Before starting this repair guide, you will need a measuring tape, small needle nose pliers, flathead pliers, and a new wire that matches the gauge of your old wire. In addition, it is recommended that you utilize your experience and knowledge in handling small tools and parts.
It is advised that you adjust your grip to comfortably hold the wire to prevent any injuries. In addition, it is recommended that you do not excessively bend any components, as this may cause further damage to your egg slicer.
Tools
Using the flat nosed pliers, pry the clamp open.
Grip the clamp and bend to a 90 degree angle.
Repeat this step for every clamp.
