Eee Pad Transformer Prime TF201 LED Chip Replacement
    1. Eee Pad Transformer Prime TF201 LED Chip Replacement, Opening Your Device: step 1, image 1 of 1
      • Power down your device.
      • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
      Ask FixBot
    2. Eee Pad Transformer Prime TF201 LED Chip Replacement: step 2, image 1 of 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: step 2, image 2 of 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: step 2, image 3 of 3
      • Insert the plastic opening tool into the seam near the corner of the device.
      • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
      • It is normal to hear snaps as the spring clips holding the screen in place are released.
      • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
      Ask FixBot
    3. Eee Pad Transformer Prime TF201 LED Chip Replacement: step 3, image 1 of 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: step 3, image 2 of 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: step 3, image 3 of 3
      • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
      • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
      • Safely place the device back on the table by laying the screen face down.
      • There will be some slight overlapping of the back of the case over the screen.
      Ask FixBot
    4. Eee Pad Transformer Prime TF201 LED Chip Replacement: step 4, image 1 of 2 Eee Pad Transformer Prime TF201 LED Chip Replacement: step 4, image 2 of 2
      • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
      • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
      Ask FixBot
    5. Eee Pad Transformer Prime TF201 LED Chip Replacement: step 5, image 1 of 1
      • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
      • Repeat the previous process to remove the other ribbon cable.
      Ask FixBot
    6. Eee Pad Transformer Prime TF201 LED Chip Replacement: step 6, image 1 of 1
      • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
      • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
      • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
      Ask FixBot
    1. Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: step 7, image 1 of 2 Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
      • Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
      Ask FixBot
Aaron Morland
346 Reputation
3 Guides authored
Cal Poly, Team 10-1, Livingston Fall 2016 Member of Cal Poly, Team 10-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G1
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 50
All Time: 745
