Up to 20% off select tools
Edifier W820NB Plus Drivers Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
136
All Time:
1,036
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If you are experiencing bad or no audio from your Edifier W820NB Plus, you might need to replace one or both drivers. The drivers are the part responsible for producing sound in headphones, See this troubleshooting page for more information.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
    1. Edifier W820NB Plus Drivers Replacement, Ear Pads: step 1, image 1 of 1
      • Start with the headphones face up and the earpads visible.
      Ask FixBot
    2. Edifier W820NB Plus Drivers Replacement: step 2, image 1 of 2 Edifier W820NB Plus Drivers Replacement: step 2, image 2 of 2
      • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
      Ask FixBot
    3. Edifier W820NB Plus Drivers Replacement: step 3, image 1 of 2 Edifier W820NB Plus Drivers Replacement: step 3, image 2 of 2
      • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
      • Repeat this procedure for the other side if necessary.
      Ask FixBot
    4. Edifier W820NB Plus Drivers Replacement: step 4, image 1 of 1
      • Repeat for the other side if necessary.
      Ask FixBot
    1. Edifier W820NB Plus Drivers Replacement, Drivers: step 5, image 1 of 1
      • Identify the driver you wish to replace.
      • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
      Ask FixBot
    2. Edifier W820NB Plus Drivers Replacement: step 6, image 1 of 2 Edifier W820NB Plus Drivers Replacement: step 6, image 2 of 2
      • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
      Ask FixBot
    3. Edifier W820NB Plus Drivers Replacement: step 7, image 1 of 3 Edifier W820NB Plus Drivers Replacement: step 7, image 2 of 3 Edifier W820NB Plus Drivers Replacement: step 7, image 3 of 3
      • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
      • Insert a Jimmy in the seam between the driver assembly and driver housing.
      • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
      Ask FixBot
    4. Edifier W820NB Plus Drivers Replacement: step 8, image 1 of 2 Edifier W820NB Plus Drivers Replacement: step 8, image 2 of 2
      • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
      Ask FixBot
    5. Edifier W820NB Plus Drivers Replacement: step 9, image 1 of 2 Edifier W820NB Plus Drivers Replacement: step 9, image 2 of 2
      • Skip this step if you are completing a battery replacement.
      • Repeat the procedure for the other driver if necessary.
      • Desolder the four driver connections from the motherboard.
      • Remove the driver assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Happy Zhang
438 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 136
All Time: 1,036
