Edco KL14 Arbor Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
11
Past 7 Days:
23
Past 30 Days:
64
All Time:
2,057
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace a damaged arbor assembly on the Edco Cement Saw KL1465H.
    1. Edco KL14  Arbor Replacement, Disengage the Spark Plug: step 1, image 1 of 2 Edco KL14  Arbor Replacement, Disengage the Spark Plug: step 1, image 2 of 2
      • Before you begin, ensure that the machine is powered down and cool to the touch.
      • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
      • Grab the plastic spark plug cap at the end of the spark plug wire.
      • Firmly pull to disconnect the spark plug cap from the spark plug.
      Ask FixBot
    2. Edco KL14  Arbor Replacement, Place Wheel Chocks: step 2, image 1 of 3 Edco KL14  Arbor Replacement, Place Wheel Chocks: step 2, image 2 of 3 Edco KL14  Arbor Replacement, Place Wheel Chocks: step 2, image 3 of 3
      • To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
      Ask FixBot
    1. Edco KL14  Arbor Replacement, Remove the Arbor Guard: step 3, image 1 of 2 Edco KL14  Arbor Replacement, Remove the Arbor Guard: step 3, image 2 of 2
      • Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
      • Remove the arbor guard.
      Ask FixBot
    2. Edco KL14  Arbor Replacement, Remove the Belt Guard: step 4, image 1 of 3 Edco KL14  Arbor Replacement, Remove the Belt Guard: step 4, image 2 of 3 Edco KL14  Arbor Replacement, Remove the Belt Guard: step 4, image 3 of 3
      • Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
      • Remove the belt guard.
      Ask FixBot
    1. Edco KL14  Arbor Replacement, Arbor: step 5, image 1 of 2 Edco KL14  Arbor Replacement, Arbor: step 5, image 2 of 2
      • Lower the guide bar all the way down until it rests on the work surface.
      Ask FixBot
    2. Edco KL14  Arbor Replacement, Remove the Blade: step 6, image 1 of 1
      • Use a 9/16-inch wrench to remove the bolt securing the blade cover.
      Ask FixBot
    3. Edco KL14  Arbor Replacement: step 7, image 1 of 1
      • Use a 3/4-inch wrench to loosen the blade cover pivot bolt, but do not remove it.
      Ask FixBot
    4. Edco KL14  Arbor Replacement: step 8, image 1 of 2 Edco KL14  Arbor Replacement: step 8, image 2 of 2
      • Raise the blade cover all the way up to expose the cutting blade.
      • Work slowly and take extra precautions when working around the exposed cutting blade.
      Ask FixBot
    5. Edco KL14  Arbor Replacement: step 9, image 1 of 3 Edco KL14  Arbor Replacement: step 9, image 2 of 3 Edco KL14  Arbor Replacement: step 9, image 3 of 3
      • Use the included wrenches to remove the jam nut securing the cutting blade to the arbor.
      • Use one wrench behind the blade to secure the arbor in place as you use the other wrench to remove the jam nut.
      • The jam nut is accompanied by a lock washer. Be sure to retain it for reinstallation.
      Ask FixBot
    6. Edco KL14  Arbor Replacement: step 10, image 1 of 3 Edco KL14  Arbor Replacement: step 10, image 2 of 3 Edco KL14  Arbor Replacement: step 10, image 3 of 3
      • Remove the blade cap.
      • Reassembly Tip: Make sure the pin on the blade cap lines up with the holes on the blade and arbor.
      Ask FixBot
    7. Edco KL14  Arbor Replacement: step 11, image 1 of 3 Edco KL14  Arbor Replacement: step 11, image 2 of 3 Edco KL14  Arbor Replacement: step 11, image 3 of 3
      • Remove the blade from the arbor.
      • Use extreme care while removing the blade to avoid injury.
      Ask FixBot
    8. Edco KL14  Arbor Replacement: step 12, image 1 of 1
      • Use a 9/16-inch wrench to remove the four bolts securing the arbor assembly to the concrete saw.
      Ask FixBot
    9. Edco KL14  Arbor Replacement: step 13, image 1 of 2 Edco KL14  Arbor Replacement: step 13, image 2 of 2
      • Support the arbor assembly from the bottom and tilt the left side down to remove it from the belts.
      Ask FixBot
    10. Edco KL14  Arbor Replacement: step 14, image 1 of 2 Edco KL14  Arbor Replacement: step 14, image 2 of 2
      • Remove the arbor assembly.
      • Reassembly Tip: Reinstall a mounting bolt on the blade side to hold the arbor assembly in place. Then use a clamp to help line up the remaining mounting bolt holes, as the tension of the belts will make it difficult to do this by hand.
      Ask FixBot
2 other people completed this guide.
Craig Lloyd
43,713 Reputation
82 Guides authored
1 Guide Comment
I'd really like to see this type of guide done on a machine that has been USED by say rental customers! I do appreciate the guides but they are somewhat unrealistic because everything is new. Also, I didn't see a part number for a whole and assembled arbor. That would be nice to have.
MICHEL - Reply Share
Past 24 Hours: 11
Past 7 Days: 23
Past 30 Days: 64
All Time: 2,057
