Ecovacs Deebot 900 Wheel Replacement
    1. Ecovacs Deebot 900 Wheel Replacement, Battery: step 1, image 1 of 1
      • Remove all the brushes from the Deebot.
      Ask FixBot
    2. Ecovacs Deebot 900 Wheel Replacement: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
      Ask FixBot
    3. Ecovacs Deebot 900 Wheel Replacement: step 3, image 1 of 1
      • Remove the battery cover.
      Ask FixBot
    4. Ecovacs Deebot 900 Wheel Replacement: step 4, image 1 of 1
      • Using the two white straps on the sides of the battery, gently remove the battery. ​
      • Be careful not to rip out the battery cable.
      Ask FixBot
    5. Ecovacs Deebot 900 Wheel Replacement: step 5, image 1 of 1
      • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
      Ask FixBot
    1. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: step 6, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement, Front Bumper: step 6, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
      Ask FixBot
    2. Ecovacs Deebot 900 Wheel Replacement: step 7, image 1 of 1
      • Remove the black strip on the bottom of the bumper.
      Ask FixBot
    3. Ecovacs Deebot 900 Wheel Replacement: step 8, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement: step 8, image 2 of 2
      • Carefully lift up the bumper untill it pops out of place.​
      Ask FixBot
    4. Ecovacs Deebot 900 Wheel Replacement: step 9, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement: step 9, image 2 of 2
      • Disconnect the two cables connecting the bumper to the body of the Deebot.
      • Remove the front bumper from the device.
      Ask FixBot
    1. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: step 10, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement, Bottom Case: step 10, image 2 of 2
      • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
      Ask FixBot
    2. Ecovacs Deebot 900 Wheel Replacement: step 11, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement: step 11, image 2 of 2
      • Insert a Jimmy into the seam and work all the way around the robot.
      • Disconnect the two cables and remove the bottom case from the device.
      Ask FixBot
    1. Ecovacs Deebot 900 Wheel Replacement, Motherboard: step 12, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
      Ask FixBot
    2. Ecovacs Deebot 900 Wheel Replacement: step 13, image 1 of 1
      • Carefully remove the ribbon cables connected to the top of motherboard.
      • Keep track of where the cables connect to the motherboard.
      Ask FixBot
    3. Ecovacs Deebot 900 Wheel Replacement: step 14, image 1 of 1
      • Remove the last three ribbon cables on the underside of the motherboard.​
      Ask FixBot
    4. Ecovacs Deebot 900 Wheel Replacement: step 15, image 1 of 1
      • Lift the motherboard out of the Deebot and remove it from the device.
      Ask FixBot
    1. Ecovacs Deebot 900 Wheel Replacement, Wheel: step 16, image 1 of 1
      Tool used on this step:
      Buy
      • Using a screwdriver or tweezers, Gently lift the spring upward, ensuring not to apply excessive force that could damage surrounding components. Once the spring is loosened, grip it securely and pull it off from one side, allowing the tension to release naturally. Take care to note the spring’s orientation and placement for reassembly later.
      Ask FixBot
    2. Ecovacs Deebot 900 Wheel Replacement: step 17, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement: step 17, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the four screws securing the wheel assembly in place. Begin by loosening each screw slightly to evenly distribute pressure, then fully unscrew them one at a time. Be sure to set the screws aside in a safe location for reassembly later. Gently lift the wheel assembly out of its housing.
      Ask FixBot
    3. Ecovacs Deebot 900 Wheel Replacement: step 18, image 1 of 1
      • Gently pry off the wheel cover using your fingers or a plastic tool, applying light pressure to release it. Set the cover aside for reassembly.
      Ask FixBot
    4. Ecovacs Deebot 900 Wheel Replacement: step 19, image 1 of 3 Ecovacs Deebot 900 Wheel Replacement: step 19, image 2 of 3 Ecovacs Deebot 900 Wheel Replacement: step 19, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
      Ask FixBot
    5. Ecovacs Deebot 900 Wheel Replacement: step 20, image 1 of 2 Ecovacs Deebot 900 Wheel Replacement: step 20, image 2 of 2
      • Lift the wheel assembly carefully, ensuring the attached sensor (black cable) comes out with it. Handle the sensor gently to avoid damage
      Ask FixBot
8 other people completed this guide.
6 Guide Comments
Thanks, it helps a lot
Agoston David - Reply Share
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - Reply Share
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - Reply Share
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - Reply Share
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - Reply Share
Past 24 Hours: 8
Past 7 Days: 46
Past 30 Days: 175
All Time: 51,544
