Ecovacs Deebot 900 Bottom Case Replacement
    1. Ecovacs Deebot 900 Bottom Case Replacement, Battery: step 1, image 1 of 1
      • Remove all the brushes from the Deebot.
      Ask FixBot
    2. Ecovacs Deebot 900 Bottom Case Replacement: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
      Ask FixBot
    3. Ecovacs Deebot 900 Bottom Case Replacement: step 3, image 1 of 1
      • Remove the battery cover.
      Ask FixBot
    4. Ecovacs Deebot 900 Bottom Case Replacement: step 4, image 1 of 1
      • Using the two white straps on the sides of the battery, gently remove the battery. ​
      • Be careful not to rip out the battery cable.
      Ask FixBot
    5. Ecovacs Deebot 900 Bottom Case Replacement: step 5, image 1 of 1
      • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
      Ask FixBot
    1. Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: step 6, image 1 of 2 Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: step 6, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
      Ask FixBot
    2. Ecovacs Deebot 900 Bottom Case Replacement: step 7, image 1 of 1
      • Remove the black strip on the bottom of the bumper.
      Ask FixBot
    3. Ecovacs Deebot 900 Bottom Case Replacement: step 8, image 1 of 2 Ecovacs Deebot 900 Bottom Case Replacement: step 8, image 2 of 2
      • Carefully lift up the bumper untill it pops out of place.​
      Ask FixBot
    4. Ecovacs Deebot 900 Bottom Case Replacement: step 9, image 1 of 2 Ecovacs Deebot 900 Bottom Case Replacement: step 9, image 2 of 2
      • Disconnect the two cables connecting the bumper to the body of the Deebot.
      • Remove the front bumper from the device.
      Ask FixBot
    1. Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: step 10, image 1 of 2 Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: step 10, image 2 of 2
      • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
      Ask FixBot
    2. Ecovacs Deebot 900 Bottom Case Replacement: step 11, image 1 of 2 Ecovacs Deebot 900 Bottom Case Replacement: step 11, image 2 of 2
      • Insert a Jimmy into the seam and work all the way around the robot.
      • Disconnect the two cables and remove the bottom case from the device.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 42
All Time: 3,289
