Ecovacs Deebot 900 Battery Replacement
    1. Ecovacs Deebot 900 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove all the brushes from the Deebot.
      Ask FixBot
    2. Ecovacs Deebot 900 Battery Replacement: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
      Ask FixBot
    3. Ecovacs Deebot 900 Battery Replacement: step 3, image 1 of 1
      • Remove the battery cover.
      Ask FixBot
    4. Ecovacs Deebot 900 Battery Replacement: step 4, image 1 of 1
      • Using the two white straps on the sides of the battery, gently remove the battery. ​
      • Be careful not to rip out the battery cable.
      Ask FixBot
    5. Ecovacs Deebot 900 Battery Replacement: step 5, image 1 of 1
      • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
      Ask FixBot
9 other people completed this guide.
6 Guide Comments
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - Reply Share
Where can replacement battery packs be acquired from?
Larry Smith - Reply Share
You can find the battery at Taobao online shopping
Jimmy - Reply Share
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - Reply Share
Past 24 Hours: 10
Past 7 Days: 114
Past 30 Days: 372
All Time: 31,450
