Eco X Gear Voice Coil Replacement
  1. Eco X Gear Voice Coil Replacement, Frame: step 1, image 1 of 1
    • Disconnect any power source and/or turn off device.
    Ask FixBot
  2. Eco X Gear Voice Coil Replacement: step 2, image 1 of 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
    Ask FixBot
  3. Eco X Gear Voice Coil Replacement: step 3, image 1 of 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
    Ask FixBot
  4. Eco X Gear Voice Coil Replacement: step 4, image 1 of 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
    Ask FixBot
  5. Eco X Gear Voice Coil Replacement, Voice Coil: step 5, image 1 of 1
    • Disconnect the wiring to improve accessibility to the cones.
    Ask FixBot
  6. Eco X Gear Voice Coil Replacement: step 6, image 1 of 2 Eco X Gear Voice Coil Replacement: step 6, image 2 of 2
    • Remove the four screws that hold down the speaker and pry up the speaker from the frame.
    Ask FixBot
  7. Eco X Gear Voice Coil Replacement: step 7, image 1 of 1
    • Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
    Ask FixBot
James Lipsett
625 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 452
