Up to 20% off select tools
Eco X Gear LED Display Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
97
All Time:
620
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
You will need a phillips head screw driver, needle nose pliers, solder, and a soldering iron to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
    1. Eco X Gear LED Display Replacement, Frame: step 1, image 1 of 1
      • Disconnect any power source and/or turn off device.
      Ask FixBot
    2. Eco X Gear LED Display Replacement: step 2, image 1 of 1
      • Remove the 15 rubber plugs from the cavities using needle nose pliers.
      Ask FixBot
    3. Eco X Gear LED Display Replacement: step 3, image 1 of 1
      • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
      Ask FixBot
    4. Eco X Gear LED Display Replacement: step 4, image 1 of 1
      • Carefully separate the two sections of the frame.
      • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
      Ask FixBot
    1. Eco X Gear LED Display Replacement, LED Display: step 5, image 1 of 1
      • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
      Ask FixBot
    2. Eco X Gear LED Display Replacement: step 6, image 1 of 1
      • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
      Ask FixBot
Author
with
James Lipsett
625 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 97
All Time: 620
