Eco X Gear Gasket Replacement
  1. Eco X Gear Gasket Replacement, Frame: step 1, image 1 of 1
    • Disconnect any power source and/or turn off device.
    Ask FixBot
  2. Eco X Gear Gasket Replacement: step 2, image 1 of 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
    Ask FixBot
  3. Eco X Gear Gasket Replacement: step 3, image 1 of 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
    Ask FixBot
  4. Eco X Gear Gasket Replacement: step 4, image 1 of 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
    Ask FixBot
  5. Eco X Gear Gasket Replacement, Gasket: step 5, image 1 of 1
    • Inspect the gasket around the perimeter of the frame. Remove the gasket using your fingers or needle nose pliers.
    Ask FixBot
James Lipsett
625 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 301
