Eco X Gear Battery Replacement
    1. Eco X Gear Battery Replacement, Frame: step 1, image 1 of 1
      • Disconnect any power source and/or turn off device.
      Ask FixBot
    2. Eco X Gear Battery Replacement: step 2, image 1 of 1
      • Remove the 15 rubber plugs from the cavities using needle nose pliers.
      Ask FixBot
    3. Eco X Gear Battery Replacement: step 3, image 1 of 1
      • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
      Ask FixBot
    4. Eco X Gear Battery Replacement: step 4, image 1 of 1
      • Carefully separate the two sections of the frame.
      • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
      Ask FixBot
    1. Eco X Gear Battery Replacement, Battery: step 5, image 1 of 1
      • Disconnect the wiring to improve accessibility to the battery.
      Ask FixBot
    2. Eco X Gear Battery Replacement: step 6, image 1 of 2 Eco X Gear Battery Replacement: step 6, image 2 of 2
      • Remove the two screws that hold that bracket, securing the battery in place.
      Ask FixBot
    3. Eco X Gear Battery Replacement: step 7, image 1 of 1
      • Disconnect the wires that hold the batteries down to the motherboard.
      Ask FixBot
    4. Eco X Gear Battery Replacement: step 8, image 1 of 1
      • Pry the battery from the frame using your hands or an opening pick.
      Ask FixBot
    5. Eco X Gear Battery Replacement: step 9, image 1 of 1
      • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
      Ask FixBot
James Lipsett
625 Reputation
6 Guides authored
3 Guide Comments
Where to get the new battery?
James Chen - Reply Share
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 1,489
