Up to 20% off select tools
Eclipse 180G2 Outer Case Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
92
All Time:
2,103
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Removal of the internal circuit is crucial step in replacing any component. This guide is the first step in replacing any part on the device.
    1. Eclipse 180G2 Outer Case Replacement, Outer Case: step 1, image 1 of 2 Eclipse 180G2 Outer Case Replacement, Outer Case: step 1, image 2 of 2
      • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
      • Use a spudger to remove the plastic plate from the bottom of the player.
      Ask FixBot
    2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 1 of 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 2 of 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 3 of 3
      • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
      • Use the spudger to push the USB port on the bottom of the device inward.
      • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
      Ask FixBot
3 other people completed this guide.
Author
with
Jesse Minor
677 Reputation
3 Guides authored
USF Tampa, Team 1-4, Tanski Winter 2015 Member of USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Members
60 Guides authored
1 Guide Comment
What if there is no charge port or USB port there no longer?
May 303 - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 92
All Time: 2,103
