Up to 20% off select tools
Eclipse 180G2 MP3 Video Player speaker Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
93
All Time:
1,685
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 - 55 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
The following guide is for the speaker replacement of an Eclipse 180G2 MP3 video player. This guide will assist the reader in replacing the speaker on their personal device. This instruction set has a moderate difficulty level and It is important to recognize you will be handling the device’s circuit board and open wires. Without a functioning speaker, the device will not perform to its highest potential because sound will be unavailable. It will be evident that it needs replacement if there is no sound coming out when attempting to play media. Soldering is required to attach a replacement.
    1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: step 1, image 1 of 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: step 1, image 2 of 2
      • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
      • Use a spudger to remove the plastic plate from the bottom of the player.
      Ask FixBot
    2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: step 2, image 1 of 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: step 2, image 2 of 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: step 2, image 3 of 3
      • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
      • Use the spudger to push the USB port on the bottom of the device inward.
      • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
      Ask FixBot
    1. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: step 3, image 1 of 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: step 3, image 2 of 2
      • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
      • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
      • You will need to solder the new speaker wires to connect it to the device.
      Ask FixBot
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
3 other people completed this guide.
Author
with
Jesse Minor
677 Reputation
3 Guides authored
USF Tampa, Team 1-4, Tanski Winter 2015 Member of USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 93
All Time: 1,685
