Up to 20% off select tools
Eclipse 180BL Touch Pad Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
108
All Time:
1,395
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
  • Screwdriver
    $33.96 $39.95
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If you have an unresponsive touch pad, sticking buttons, or just want a fresh touch pad in your device, this guide is for you!
    1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: step 1, image 1 of 1
      • Remove the two screws at the bottom of the device.
      • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
      • The two screws are 1/8 inch in length.
      • Remove the cover to reveal the internal component.
      Ask FixBot
    2. Eclipse 180BL Touch Pad  Replacement: step 2, image 1 of 3 Eclipse 180BL Touch Pad  Replacement: step 2, image 2 of 3 Eclipse 180BL Touch Pad  Replacement: step 2, image 3 of 3
      • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
      • This will release the tension on the multiple parts. One of which will be the touch pad.
      • The touch pad can now be easily replaced.
      • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Thomas Schwarz
523 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 108
All Time: 1,395
