EchoMaster MRC-WLP43 Wire Port Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
51
All Time:
449
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
When the underlying issue is revolved around the Wire port you can follow these steps on how to replace it. *Note that when replacing your Wire port, you are replacing the entire motherboard because they are attached. The only tool you will need is a #1 Phillips head screwdriver.
Tools
    1. EchoMaster MRC-WLP43 Wire Port Replacement, Wire Port: step 1, image 1 of 1
      • Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
      • Don't lose your screws!
      Ask FixBot
    2. EchoMaster MRC-WLP43 Wire Port Replacement: step 2, image 1 of 2 EchoMaster MRC-WLP43 Wire Port Replacement: step 2, image 2 of 2
      • Carefully lift the back along with the screen then flip it around slowly so the back is placed down on the table.
      • The back is connected to the motherboard and screen so lift with caution!
      • Lift your screen above the motherboard and set it down.
      Ask FixBot
    3. EchoMaster MRC-WLP43 Wire Port Replacement: step 3, image 1 of 1
      • There are three screws on the motherboard. Unscrew each one of the three 1.4 mm Phillips #1 screws.
      Ask FixBot
    4. EchoMaster MRC-WLP43 Wire Port Replacement: step 4, image 1 of 2 EchoMaster MRC-WLP43 Wire Port Replacement: step 4, image 2 of 2
      • Once the screws are out, you can then remove the yellow strip connecting the screen to the motherboard.
      • There is a black tab that you can carefully flip up with your fingernail or a flathead screwdriver. Once it's flipped up you can easily slide the yellow ribbon out.
      Ask FixBot
    5. EchoMaster MRC-WLP43 Wire Port Replacement: step 5, image 1 of 2 EchoMaster MRC-WLP43 Wire Port Replacement: step 5, image 2 of 2
      • When everything is unscrewed and removed you can take your motherboard out.
      • Your charger port is attached to the motherboard. To replace it you can simply retrace these steps.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 449
