EasySMX X15 Vibration Motor Replacement
  1. EasySMX X15 Vibration Motor Replacement, Bottom Casing: step 1, image 1 of 2 EasySMX X15 Vibration Motor Replacement, Bottom Casing: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
    Ask FixBot
  2. EasySMX X15 Vibration Motor Replacement, Battery: step 2, image 1 of 3 EasySMX X15 Vibration Motor Replacement, Battery: step 2, image 2 of 3 EasySMX X15 Vibration Motor Replacement, Battery: step 2, image 3 of 3
    • Push on alternating sides of the connector to disconnect the red battery cable from the board.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Pull from the tab, not the cables, to avoid damaging them.
    Ask FixBot
  3. EasySMX X15 Vibration Motor Replacement: step 3, image 1 of 1
    • Use a spudger to pry the battery loose from the controller.
    • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
    • Remove the battery.
    • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
    Ask FixBot
  4. EasySMX X15 Vibration Motor Replacement, Vibration Motor: step 4, image 1 of 1
    Ask FixBot
  5. EasySMX X15 Vibration Motor Replacement: step 5, image 1 of 1
    • Slide the motor out of the housing.
    Ask FixBot
ShawnDetiveaux
646 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 365
