Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓Replacing the triggers on your EasySMX X15 Controller is a straightforward process that can help restore the responsiveness of your controller's shoulder buttons. This guide will walk you through the steps using tools commonly available at home, ensuring a quick and easy fix.
Note: You don't have to remove the battery as shown in Step 3, but make sure to disconnect the battery cable from the board before proceeding to the next step.
Tools
Spudger4.9
Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
Push on alternating sides of the connector to disconnect the red battery cable from the board.
Disconnect the vibration motor cables from the connectors on the circuit board.
Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
Use a Phillips #00 screwdriver to remove the two 4mm screws located on each side of the triggers.
Carefully lift the triggers out to remove them.
1 Guide Comment
where do i find the replacment trigers am looking for the model x5pro
