EasySMX X15 Main Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
53
All Time:
570
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If your EasySMX X15 stops working then you may need to replace the main circuit board. This guide will show you how to replace the circuit board if that is the case.
Tools
    1. EasySMX X15 Main Board Replacement, Bottom Casing: step 1, image 1 of 2 EasySMX X15 Main Board Replacement, Bottom Casing: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
      • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
      • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
      Ask FixBot
    1. EasySMX X15 Main Board Replacement, Battery: step 2, image 1 of 3 EasySMX X15 Main Board Replacement, Battery: step 2, image 2 of 3 EasySMX X15 Main Board Replacement, Battery: step 2, image 3 of 3
      • Push on alternating sides of the connector to disconnect the red battery cable from the board.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • Pull from the tab, not the cables, to avoid damaging them.
      Ask FixBot
    2. EasySMX X15 Main Board Replacement: step 3, image 1 of 1
      • Use a spudger to pry the battery loose from the controller.
      • The battery is glued onto the control board, so it may take a bit of work to release it from the adhesive.
      • Remove the battery.
      • Don't bend or pierce the battery. If the battery is swollen, follow the guidelines outlined in this article.
      Ask FixBot
    1. EasySMX X15 Main Board Replacement, Main Board: step 4, image 1 of 1
      • Disconnect the vibration motor cables from the connectors on the circuit board.
      • Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
      Ask FixBot
    2. EasySMX X15 Main Board Replacement: step 5, image 1 of 1
      • Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
      Ask FixBot
ShawnDetiveaux
646 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 53
All Time: 570
