Introduction
The D-Pad is central to many game experiences, and due to use can begin to fail over time. This guide will instruct the user in the process of replacing the D-Pad for the EasySMX-15.
Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
Disconnect the vibration motor cables from the connectors on the circuit board.
Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
Use the Phillips #00 screwdriver to remove the four 4 mm screws securing the D-pad to the controller casing.
Lift the back of the D-pad, along with the membrane, to remove them from the controller.
Lift up the case, allowing the D-pad to detach from the top of the casing.
