Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓Over time, the buttons on your EasySMX X15 controller may become less responsive or get stuck. Replacing the buttons is a relatively simple process that you can do at home with a few basic tools. This guide will walk you through how to replace the buttons.
Note: You don't need to remove the battery as shown in Step 3. However, it is important to disconnect the battery from the board before you move on.
Tools
Spudger4.9
Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
Push on alternating sides of the connector to disconnect the red battery cable from the board.
Disconnect the vibration motor cables from the connectors on the circuit board.
Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
To reassemble your device, follow these instructions in reverse order
