EasySMX ESM-9110 Turbo Button Replacement
    1. EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: step 1, image 1 of 2 EasySMX ESM-9110 Turbo Button Replacement, Handle Covers: step 1, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
      Ask FixBot
    2. EasySMX ESM-9110 Turbo Button Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool into the slit on the side of controller.
      • Wiggle the tool until the cover becomes loose.
      • Repeat this on the other side of Controller.
      • Go slow. Take your time removing the handle covers.
      Ask FixBot
    3. EasySMX ESM-9110 Turbo Button Replacement: step 3, image 1 of 1
      • Remove the faceplate.
      • Repeat on the other side of the controller.
      Ask FixBot
    1. EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 1 of 3 EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 2 of 3 EasySMX ESM-9110 Turbo Button Replacement, Turbo Button: step 4, image 3 of 3
      • Use a Philips #000 screwdriver to remove the six 20 mm screws from the controller's faceplate.
      Ask FixBot
    2. EasySMX ESM-9110 Turbo Button Replacement: step 5, image 1 of 3 EasySMX ESM-9110 Turbo Button Replacement: step 5, image 2 of 3 EasySMX ESM-9110 Turbo Button Replacement: step 5, image 3 of 3
      • Using a soldering iron, solder the turbo button.
      Ask FixBot
Melanie Rodriguez
418 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 35
All Time: 552
