EasySMX ESM-9110 Backplate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
66
All Time:
788
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will teach you how to replace the backplate of the EasySMX ESM-9110 controller.
Tools
    1. EasySMX ESM-9110 Backplate Replacement, Handle Covers: step 1, image 1 of 2 EasySMX ESM-9110 Backplate Replacement, Handle Covers: step 1, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
      Ask FixBot
    2. EasySMX ESM-9110 Backplate Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool into the slit on the side of controller.
      • Wiggle the tool until the cover becomes loose.
      • Repeat this on the other side of Controller.
      • Go slow. Take your time removing the handle covers.
      Ask FixBot
    3. EasySMX ESM-9110 Backplate Replacement: step 3, image 1 of 1
      • Remove the faceplate.
      • Repeat on the other side of the controller.
      Ask FixBot
    1. EasySMX ESM-9110 Backplate Replacement, Backplate: step 4, image 1 of 3 EasySMX ESM-9110 Backplate Replacement, Backplate: step 4, image 2 of 3 EasySMX ESM-9110 Backplate Replacement, Backplate: step 4, image 3 of 3
      • Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
      • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
      • Screw extender should only be used to unscrew two of the six screws. Do not use for all six.
      Ask FixBot
    2. EasySMX ESM-9110 Backplate Replacement: step 5, image 1 of 1
      • Remove the faceplate of the controller by lifting it directly up from the backplate.
      • Be gentle. The controllers backplate is still attached to the faceplate.
      Ask FixBot
    3. EasySMX ESM-9110 Backplate Replacement: step 6, image 1 of 3 EasySMX ESM-9110 Backplate Replacement: step 6, image 2 of 3 EasySMX ESM-9110 Backplate Replacement: step 6, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
      • Remove the daughterboard once screws are off.
      • Be gentle when removing the daughterboard. The daughterboard is still attached to the faceplate.
      Ask FixBot
Melanie Rodriguez Cruz
418 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 66
All Time: 788
